hi, due to no heat from my heater ,i replaced the thermostat in the housing which joins the bottom radiator hose on my 2001 t4,
i bleed the system and i am getting a little heat but not much temp gauge is sitting on 90.every thing else is fine .my question is .is there another thermostat on the t4 block?looking from the front of the van under the header bottle on the side of the block there is a black plastic housing which looks like a thermostat housing there is a hose running down from the heater matrix to it any ideas guys ?
regards cyclone
Somebody stop me!
thanks for the quick reply jimmyjames, still would like to know what that housing is though ?
Its just a waterway from the head bud T:T:T: Have you bled the system from the pipes that pass through the bulkhead?? Is your heater cable operating the lever under the bonnet ok??
