701 - 718 of 718 Posts
Hi Johnyo
I know this is an old feed however can you or anyone else advise if replacing both top mount struts worked? I have a 2005 T30 130bph transporter which has a loud knocking sound coming from the steering. It has had this since i bought it 3 years ago.
hi. the noise/knock has disappeared. i'm putting some miles in to see if it returns.T:
Hi new to forum and new t5' 63 plate owner.
Browsing through forum and came across this problem about knocking steering colum ' when someone posted not so much as a knock
But more of a notchy tight spot when turning the steering wheel, I'm a fitter for a crane hire company' on some of our new cranes
( German liehberr) the steering colum uses the same knuckle joints as many other vehicles have . We started getting this problem and it had me stumped for a few hours after checking steering Rams and plpes and pumps and pressure tests . So out of desperation I got the driver to keep turning the steering while I emptied a tin of wd40 on the two knuckle joints 20 mins later he was turning the steering with one finger smooth as silk . Hope this might help someone . Just to add there same joints as I have on my t5 .
Cas.
I have the vw t5.1- 4 motion swb 180ps kombi I've had it for a while now my boss got it factory made from vw. It's got 58k on the clock. I feel times there's a small resistance I can feel when going round corners but it only happens at certain times. There is no noise and it's the standard steel wheels and there's plenty of power steering fluid and I'm very careful when I'm on the road.
Has any one else noticed this kind of play on the steering wheel?
I've been in the van since new and my boss was a sensible driver but he didn't notice the resistance that I can feel in the steering wheel.
I would be happy if I can get some of your professional feedback. Thank you
Mine too, intermittent. Thought it was due to garage knackering bearing rings when lowering but they've been replaced and despite going away for a little while, the bad sounds are back :-( As an aside, got a creak on drivers door I can't suss out either, probably never will unless I ever find someone else who's had it happen and found solution !
I have a 2011 T5 SWB, it currently has 121452km and it has the knocking on the steering wheel, especially at low speeds and over speed bumps.
according to one of the mechanics I spoke to (Not a VW dealership) this is a sickness these Kombis have and it is nothing serious, it does not affect anything... not sure how true that is:*
How bad is the creak on the door? My last T5 did that and it was the hinge pin, the pin was trying to rotate in the wrong part of the hinge due to complete lack of lubrication. I dosed it with copious amounts of easing oil and then rotated the pin with a pair of plumbers grips, got it freed off eventually with a bit of patience.
Adding my recent experience in case it's of any value.
I thought I had the steering knock issue after reading about it on this forum - 130,000km in T5.2 2010 manual 103kw lwb
A definite knocking noise at low speeds when turning the wheel to the left or right, especially audible when cold.
Have recently changed from a general mechanic to a vw specialist.
His diagnosis is that the passenger side drive shaft is stuffed - not booked in to repair till next week.
I didn't think it could possibly be the drive shaft - because I had both drive shafts replaced at 110,000km - 18 months back.
The drivers side broke - my then general mechanic advised modified splines were available and did I want to replace both while the disc brakes were being done too - I said yes - turns out the passengers side were not modified anyway so that was unnecessary - and now the side I replaced when I didn't have to - needs to be replaced again.
Certainly tests my love for my van :(
And just to confirm - had my front passenger side drive shaft and stub axle replaced (for 2nd time in 18 months) - and the knocking noise I had is gone.
Kombired
2005 2.5TDi AXE. Clunk from universal joint in the lower steering column? Reported to local VW van centre at 51000 miles.
According to the VW van centre it's a very common fault, so much so that they thought VW might contribute something towards repairing it, whilst not actually admitting it's a fault worthy of a recall, but when asked VW refused to pay anything.
Just putting up with it, stopped noticing, to be honest. It has been mentioned at MOT time but not so much as an advisory, yet.
the list so far: please quote/copy and add to the list.
Fabrik interiors
2013
T28 140 panelvan
reported at 4500 miles (noticed at 1000 miles).
Told to wait for VW to find a fix
Darran Williams
2012
T30 140 bhp panel van
8000 miles
not reported it yet (most certainly will now tho)
Californication
2011 California 180 4Motion
5000 miles
Sorted pronto by Carrs in Cornwall
Worthing plastering
2012
T28 140 swb panel van
15000 miles (noticed it at 10000 miles)
Reported it 11000 and they could not hear it so it's going back soon.
"triffic"
2013 T30SE 140 DSG
Knocked from new, now done 5000 miles
Not yet raised with VW - will do so next week
dannyrado
2012 BMT highline kombi.
Now 16k miles but it's done it from virtually new.
Not reported (because they'll say it's my lowering springs when clearly it's not!)
Edit/Delete Message
T5mkj
Mine to has it. 2013 63 plate sportline only 1400 miles and been doing it seems like from new and getting worse, not reported yet but will do so first thing Monday morning .
DaveVW
Edition 25
8000 miles
reporting fault next week
Top Sparks
61 Plate
180 Kombi.
1st knock done at 5.5k.
Started knocking again at 16k reported but told it has to be all the time.
Reported again at 19K they are going to look at it along with my paint.
Shanksy
2011 t30 panel van swb
15500 on clock just noticed the knocking this wknd
Not reported yet
1st timer
2013 84ps panel van
Started at 1400
Not reported as yet now I've seen this will do
Av_Dave
Previous Van 61 reg 102ps started knocking at around 6k still did it up 20k when I sold it.
Current van 13plate 140ps highline has been doing it from around 5k it's on 7k now
Have not reported it yet due to lack of time really. I have heard people having new steering racks fitted and the problem still returning though.
Bubble68
hi 2012 edition 25 had column replaced at 2000miles, now done 5500 and noticed slight knock today driving to NEC.
shall report it Monday.
Snowy55
60 plate
Kombi 140
40k miles Fixed by Gilders at Newark
56k miles started doing again in last couple of weeks. Only in warranty till end of October so best get on it!
langley
2012
T30 KOMBI
2022 MILES . noticed it after a few hundred miles .
Had this fault on a 54 PLATE van , think they recorded the amount of remedies to the fault by quoting colours i.e 1st supposed fix was red , 2nd supposed fix was blue etc
Will report next week as ive noticed it getting worse .
Autotecknik
2013 1,400mls done it from new got much more noticable last 200 miles, will raise it with the dealer when i get 5
Stoo
I will take mine to VW and keep you all posted.
Don't add me just yet
96wildbrew
2013 T30 140 Camper. 36,000 miles, noticed notch/knock when the van is loaded at low speed. Took it to VW commercial main dealer....unsurprisingly they couldn't find fault. Kept the invoice !!
Please add your info to the list by quoting the post and adding your info. Just makes things easier Thanks
Special Rapporteur
I don't think I've ever heard the steering knock described as a squeak. On mine it manifested itself as a clonk which you could feel through the steering wheel as much as hear. The list above is out of date - mine was fixed under warranty and has never returned.
Darren Vidler
2012
T32 140 bhp Kombi van
57000 miles
Please add me to the list
Hi guys I'm looking for some guidance I have a T5 and want to soften the ride a bit. I have
275/35zr20. 102Y XL wheels and was wondering what radious wheel and tyre to go to do that . I really like the all terrain tyer look but I do a lot of motorway driving .
Looking for a bit of advice to diagnose if I have 'the knock'!
2010 VW 5.1 Kombi Transporter - I noticed a 'clunk' from the under a van a few weeks ago when turning hard right (roundabouts, junctions etc) which seemed to disappear for a couple of weeks but now its back!
The knock seems to happen from under the centre of the van when turning the steering from centre to right and then I seems to get a creaking when turning back to centre?
I've had top mounts / drop links / track control arm / bushes / all replaced and the steering rack tightened but still haven't fixed? I've also been under the van and removed the rubber from where the column attaches to the rack on the drivers side and the knuckle looked practically brand new with plenty of grease which left me wondering if it is the same lower knuckle fault being described here?
Any advice would be very much appreciated
