Only had van a couple of weeks and noticed my doors dont stay open just shut if u arent holding them open is sumthing missing or worn out*<:)>
Have a look to see if the bolts holding the check strap to the door are still there mine had fallen outT:
sorry but wats the chrck strap:confused:
its the metal strap between the door and the a pillar on the van they stop the door opening to far when the door is open they should be visable about half way between the hinges normally goldish in color with a bit of grese on them
Hi check strap comes through door from the inside and bolts to secure it go through the door from outside and screw into the check strap You are looking for 2 bolt heads either side of the strap if they are not there they have either fallen out or sheared off
