I've just redone my passenger side door handle cable, now it's back together and having cleaned out the door mechanism with WD40, when I pull the lock the door no longer has that initial 'spring open' stage where it pushes away from the door frame, it just opens freely as if it was never latched (which it is), with no resistance where you would normally pull against the actual mechanism release on interior or exterior handle.
Apart from that the door and lock function normally, but it does mean opening it from the inside isn't as easy.
Anyone know if there might be something I might have missed when reassembling, or a part that might not be attached properly?
