Does anyone know of a dual battery box for housing leisure batteries?
I've searched everywhere and can only find single ones, the slimmest I have found to fit my battery still adds 5cm so for two battery boxes thats an extra 10cm depth- this is space I cant afford to loose especially as the batteries are going under the rock n roll seat.
I may consider going down the adaptable box route and drill holes etc in it for cable entry points.
Anyone in the know please?I:T:
ive seen doubles that fit under bonnet in t4, dont think theres room in a t5 under bonnet though.
Im sure someone on here usedtio make the t4 ones, but cant remember who- I reckon you could get one welded up to your specs if you really wanted- Matt wakestock on here might do one?
Are your batteries sealed nick. I would think provided you vent them outside, and if neccessary locate them on a plastic tray just in case they could leak, then you should be OK. If you are fitting them under the RIB, then there should be plenty of scope to fix them down securely even if they are on trays.
