does anybody know if a double seat will fit straite into replace a single passenger front seat in a carvelle i have just picked one up from another member but after looking at it im not sure it will fit unless there r differant mounting points under the carpet?? :*
Pedal box guru
In short yes! However you will only be able to mount it on 4 bolts rather than the 5 it was fitted with in it's original van.
Also it will not fit if you have a passenger side door pocket without removing the pocket.
Hope that helps.
Cheers Trev.
Hope that helps.
Cheers Trev.
cheers trev i will give it a go tomorrow then.. T:
