Hi I have a 2010 2.0l Transporter 5 GP. Engine code CAAC. Flashing coil light on, scanned using VCDS and comes up with codes 4911 & 5257 - Exhaust Gas Temperature Sensor; B1 S3 - P242A 00 [036] - Malfunction. I cleared faults and ran for a while then came back. First scan shows sensor 3 (pre DPF) as 1000∞C, (which I think is open circuit). I cleared the codes, started the engine and did a live measure of values, Exhaust gas temperature sensor 3 was showing a value of 113.4 ∞C.
Does it look like sensor 3 is faulty / on its way out? Posted below are the scan and some live data for DPF / EGT sensors etc.
Thanks in advance for any advice / help. Also appreciate any info on how to interpret the state of the DPF soot / ash levels.
Scan:
Code: [View]
Wednesday,28,September,2016,20:54:28:30670
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.1.3
Data version: 20160902 DS256
www.Ross-Tech.com
VIN: WV1ZZZ7HZAH243635 License Plate: WN10EAC
Mileage: 101090km-62814mi Repair Order: 28-09-16(2)
Chassis Type: 7H (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 69 0B
VIN: WV1ZZZ7HZAH243635 Mileage: 101090km-62814miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CH HW: 03L 907 309 K
Component: R4 2,0L EDC X32 9970
Revision: 26X32--- Serial number: 00000000000000
Coding: 01194012233400080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
ROD: EV_ECM20TDI01103L906022CH.rod
VCID: 6DD19296BCE6302A75-8038
2 Faults Found:
4911 - Exhaust Gas Temperature Sensor; B1 S3
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 101075 km
Date: 2016.09.28
Time: 20:02:40
Engine speed: 1541.00 /min
Normed load value: 57.6 %
Vehicle speed: 34 km/h
Coolant temperature: 53 ∞C
Intake air temperature: 28 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.380 V
Unlearning counter according OBD: 40
Exhaust gas temperature sensor 1: 280.1 ∞C
Exhaust gas temperature sensor 2: -0.0 ∞C
Exhaust gas temperature sensor 3: 1000.0 ∞C
Exhaust gas temperature sensor 4: 250.1 ∞C
Shut-off timer: last engine shut-off time: 47563 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 101075 km
Date: 2016.09.28
Time: 20:02:36
Engine speed: 1594.00 /min
Normed load value: 76.9 %
Vehicle speed: 35 km/h
Coolant temperature: 52 ∞C
Voltage terminal 30: 14.400 V
Exhaust gas temperature sensor 1: 314.0 ∞C
Exhaust gas temperature sensor 4: 252.8 ∞C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 508724AD89A80A9824A89174A96310
Shop #: WSC 02736 790 49152
VCID: 346747F2974CA1E27A-8060
No fault code found.
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 T HW: 7E5 907 047 T
Component: Climatic-T5 H10 0101
Revision: 00004001
Coding: 0000000002
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01002
ROD: EV_ClimaT5Basis.rod
VCID: 408F1B22DBF40D42EE-8014
1 Fault Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 31
Mileage: 101073 km
Date: 2016.09.28
Time: 19:59:07
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0254
Revision: BO047001 Serial number: 0429 272120758
Coding: B8A030382E212033002808102C2B8CD40080430F60000000320000000000
Shop #: WSC 02736 790 12345
VCID: 397976C6B02E5C8AA9-806C
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 3310
Serial number: --------------------
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 3310
Coding: 040000
Subsystem 3 - Part No SW: 3C8 959 537 B HW: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ˇ 0021
Serial number: 10000000000000083963
Coding: E20000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 A HW: 7E0 959 655 A
Component: VW10Airbag00Y H05 0011
Revision: -------- Serial number: 003E500160H3
Coding: 000000000000000000000000000000003059
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 346747F29F4CA1E27A-8060
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 7E0 920 960 A HW: 7E0 920 960 A
Component: KOMBI H16 0111
Coding: 460800
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 275DA0BE5E9ADA7ACF-8072
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0254
Revision: BO047001
Coding: 042300
VCID: 70EF8BE2A3D4DDC25E-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H16 0111
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000132260014
Coding: 0100000100000000
Shop #: WSC 12345 123 12345
VCID: 306F4BE263549DC21E-8064
End-------------------------(Elapsed Time: 03:25)--------------------------
Live data after fault codes were cleared:
Code: [View]
Address 01: Engine (03L 906 022 CH)
20:58:13
IDE00427 Particle filter: difference pressure 5 hPa
IDE00428 Particle filter: offset for differential press. 1 hPa
IDE00432 Particle filter: time since last regeneration 11332 s
IDE00433 Particle filter: oil ash volume 0.08 l
IDE00434 Particle filter: soot mass calculated 6.58 g
IDE00435 Particle filter: soot mass measured 1.87 g
IDE00436 Particle filter: kilometers since last regeneration 97598 m
IDE01361 Exhaust gas recirculation (EGR) cooler pump: specified value 95.00 %
IDE01373 EGR valve: offset closed 0.65 %
IDE01374 EGR valve: offset open -0.65 %
IDE01405-ENG104207 Status of starter activation-Bit 0 2
IDE01406-ENG104207 Service regeneration: status-Bit 0 0
IDE01407 Particle filter: fuel consumption since last regeneration 8.50 l
IDE01408 Charge limit for field regeneration 23.13 g
IDE01409 Charge limit for service regeneration 40.00 g
IDE02229 Exhaust gas temperature sensor 1 158.4 ∞C
IDE02233 Exhaust gas temperature sensor 2 -0.0 ∞C
IDE02234 Exhaust gas temperature sensor 3 113.4 ∞C
IDE02236 Exhaust gas temperature sensor 4 100.1 ∞C
IDE03270 Exhaust gas temperature sensor 1: unconditioned voltage 796.6 mV
IDE03271 Exhaust gas temperature sensor 2: unconditioned voltage 0.0 mV
IDE03273 Exhaust gas temperature sensor 3: unconditioned voltage 732.2 mV
IDE03275 Exhaust gas temperature sensor 4: unconditioned voltage 712.8 mV
IDE03353 Particle filter differential press. sensor: uncond. voltage 1042.0 mV
IDE03383 Exhaust mass flow of EGR 0.0 kg/h
IDE04652 Exhaust gas jet volume in particle filter 59.4 m≥/h
IDE04653 Simulated particle filter surface temperature 117.1 ∞C
Andy
Scan:
Code: [View]
www.Ross-Tech.com
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 101075 km
Date: 2016.09.28
Time: 20:02:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 101075 km
Date: 2016.09.28
Time: 20:02:36
Revision: 00H43001
Revision: 00004001
Coding: 0000000002
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 31
Mileage: 101073 km
Date: 2016.09.28
Time: 19:59:07
Coding: 050000
Coding: 040000
Coding: E20000
Coding: 460800
Revision: BO047001
Coding: 042300
Serial number:
Address 56: Radio
Cannot be reached
Code: [View]
20:58:13
Andy
