***Exhaust pressure sensor fault fixed***
This may save you £80+ for a new Exhaust pressure sensor should your engine light come on with this fault code.
Mine kept coming on and in due course I switched it off via my code reader only to have it come back on a few days later.
So, with nothing to loose I took off the sensor shown below. its located above the engine on my T5 2.5;
(remove the two pipes, disconnect the plug and undo the spline screw)
Use a spare piece of flexipipe to blow down the two pipes. This will identify any blockage issue you may have in the pipes. There should be no resistance and air should pass through them freely (well, mine did).
Right, onto the sensor. Take it indoors and allow to warm to room temperature. Hold it with the two pipe connectors upwards and fill with Electrical contact cleaner shown below;
Allow to stand for 1 hour. Empty out and allow to drain for 1 hour. Repeat the last step using good old UB40 spray lubricant (there's a song in there somewhere) Fill 1 hour, drain 1 hour.
Carefully blow through with Compressed air aerosol;
Re-fit sensor and reconnect plug giving it a squirt of the Electrical cleaner.
This worked for me, the next day the engine light on the dash went off by its self and has been off for weeks now.
++++I don’t know what’s inside the sensor or how it works so if you damage yours trying I take no responsibility.+++++
It worked for me and hopefully it will save lots of people an unnecessary ‘main stealer’ bill (which we can all do without).
Happy Dubbin folks.:ILU::ILU::ILU:
