1 - 14 of 14 Posts
Right,
I'm about to carpet / ply my van.
I'm going to remove panels, carpet them, carpet the metal, carpet the panels then re-attach the panels (after using Kings insulation 50mm bottom 20mm top).
I think this seems to be the correct way.....
MY QUESTION
a) How do I attach the ply? Screw back into the holes already there?
b) Drill through the ply and into the van then
should I do both with self tapping drywall (black non rusting) screws?
Thanks muchly! - nick (yellow AA)
Right,
MY QUESTION
the panels may not screw back in to the same holes as when you carpet the panels/wrap over the edges, they then sit a few mm higher,i just screwed good self tappers in without drilling - just straight through
1 - 14 of 14 Posts
