Hi all
T4 just failed the MOT cos the drivers door wont open.
Stripped off the door card to see why and its basically because of the long "coat hanger type" wire. It keeps dropping out of the inner lock mechanism because the plastic plug has broke. Tried zip tieing it on but wont have any of it as I think the wire is now bent out of shape.
Does any one know if you can buy
a) the wire seperately
b) The plastic plug things seperately?
Any part no.s much appreciated as I can imageine trying to explain this to a dealer! Also trawling google for them is a nightmare
Many thanks
is this when you try to open it from the inside handle ? if so your handle lug may be worn and it skips off the wire not catching it . common problem that is . mine hasnt got the lug you refer to and works ok .
