Mine were just held onto the shaft with tension in the ring (hammer on, hammer off). As i understand it the driveshafts are the same across the board, the only exception is pre 96 vans which have a narrower track and shorter driveshafts.thanks to jimmy and clarkey . my carravelle is a 2.5 102 acv on a 2002 plate so not sure if your abs rings will fit maybe you know jimmy .also how are these rings held in place .?? billy
Why did you remove them, didn't it fit with them on? My '01 Syncro came without ABS & the rings were on the drive shaft from new.My driveshafts came with them standard so i removed them T:T:
