my friend has a 2.5 tdi that has bneen re maped and bigger injectors he has done about 500 miles with no weight in and thenew fly wheel has broke is this a problem for any one else thanks james the van is about 164 brake
Meithered to death
The new flywheel has broke? It could be faulty or a cheap n nasty one.I have known genuine DMFs go on for thousands of miles whilst coping with a power hike.
If it was an 88BHP model to begin with then it can be converted to solid flywheel and VR6 clutch however if it was 102BHP then the DMF and clutch from a european 150BHP T4 is a good option.
hi thanks for that the it started out as 102 bhp the garrage that fitted the duel mas also fitted the bigger injectors and also re map
