I found this in ebay today for only £3.99
It's a cable that converts the the older 2x2 connector (pre 96) to the new style obdII connector, which should then enable you to use the usual vag-com and other hopefully any other diagnosis tools.
The cable
The connector
Found just above the fusebox under the dash on the drivers side
Discussion Starter · #2 · (Edited)
Found a nice tutorial on an autobox vag-com diagnosis, hopefully be doing this myself next week. Lots of other handy tutorials with the vagcom on there also.
http://www.ilexa.co.uk/vagmovies/auto_trans.htm
And more specifically to my investigation the auto gearbox temp procedure:
ATF Temperature, checking:
Automatic Transmission Fluid temperature needs to be within a specified range when checking the fluid level. See your Factory Repair Manual for the range for your vehicle.
[Select]
[02 - Auto Trans]
[Meas. Blocks - 08]
Set group to "005" (May be group 002 or 004 in some vehicles - again check the Repair Manual).
[Go!]
The value in field 1 should be ATF temp in °C
