Hi, I have a 03 2.5 tdi blu i .
Every week i need to top up the coolant! checked the oil cap and oil level and its not being lost there, pressure tested the bottle and hose's and there fine too.
after narrowing it down to the pump my problem is that I was told to replace it even though its pumping well , the engine hasn't over heated or run hot!
Can you over haul it?
Can you try a gaskit or part to stop the leak in any way,
If it needs replacing can you get an after markit one for less than main dealer prices?
are they easy to fit? Anything else i should do while on this job?
Brian
Brian
