What age is van ect I think I am correct in saying most trucks pre 2000 have to be chipped ecu out new chip in.
Anything later can be done via cable hope this helps markT:
I think you should be able to flash it rather than removing it.......speak to a remap firm theyl soon tell you......but pretty sure yours just needs flashing
Transporter Tuning Specialist
van is 2000 cheers markT: anybody els confirm this
Mark,
If you have a MAP sensor on the boost intake pipe you have the later type of Bosch EDC15 that can be flashed over the OBD port, now if you do not have a MAP sensor but have a vac pipe going to an ECU behind the N/S Head light you have the older MSA15 engine control unit that has a pair of PLCC32 27C010 chips that need to be de soldered then new ones soldered in place to tune this, known as Chip Tuning over Remapping (same results but just a different way of going about it)
Regards
Martin
PendlePerformance
www.pendleperformance.com
