Any reason why they dont make any with a 60mm drop?? They ought to, someone must be able to persuede them to T:T:T:
And dont know if its a tuv approval thing being there van springs .Any reason why they dont make any with a 60mm drop?? They ought to, someone must be able to persuede them to T:T:T:
And that my issue and i guess the original OPs reason for the questionWouldnt sit very low on your van at all :ILU:
And its things said like this is why im torn between good springs with not much drop and lower springs that have no quality .coilbound CMC ones.
I'm hoping there are some decent 60's out there somewhere, just need to find them! 40mm isn't low enoughAnd its things said like this is why im torn between good springs with not much drop and lower springs that have no quality .
Let me know if you find some T:I'm hoping there are some decent 60's out there somewhere, just need to find them! 40mm isn't low enough![]()
Hopefully someone will see this thread and pipe up with some ideas :*:*:*Let me know if you find some T:
Mmm intresting T:FWIW i have just fired an email to Eibach UK to see if they would consider making some 60mm drop kits. I will let you know how it goes, fingers crossed T:T:
this is my problemany lowering spring with little weight does give a less than reported drop.
i got an ex coca cola van im currently converting on -60 t4srus springs and its dropped a bit but not 60mm cos its empty.
i got -40 eibachs on my westy and its waaayy lower than the coke van:
That would be a good solution if the kit is tidyi've been looking at the new adjustable rear spring coil over type sets that blue bird cmc and prosport but i hav'nt had any feed back on them this might suit you aswell as me if you want to carry a bit more weight just lift the back up more:*
