Hi
My drivers door window has become intermittently faulty, refusing to close. It would appear it's a common problem with the switch getting wet.
I've trawled various thread trying to work out how hard or easy it is to replace the switch, and of course it is easy (when you know the answer). There is no need to dismantle the door and literally took me 2 minutes to remove.
So as I took mine out for the first time, I took a few pictures to show how it's done. The part number is blurred on my switch (2009 T30) but I expect TPS will know the part when I ring them. I've liberally sprayed it with contact cleaner, and if that doesn't work I'll shell out for a new one.
Anyway, hope this helps someone.
Martin
Martin
