Hi all, this is a first post so its exciting to see what the outcome will be.
I have a 92 t4 and l changed it all in these 10years l owned it, but never the fridge box, and now it starts to cut off and blink at about 12,4volts, ca., but it always did this at 11,8, so is there any way l can adjust this turn off funcion back down to 11,8volts, or whatever it should be? Thanks guys...
Richard
Somewhere around the switch or underneath you should see a switch with 3 settings.
Thanks but which switch are you referring to as the digital command has only temp, battery, star for fridge with exclamation mark and up down arrows. Are you Norwegian
Check out the up/down switch. A picture will help. I live in Norway. Do you?
