The passenger door went a bit strange about a year ago. It would open with the key fob but not shut with it and the button on the dash was flashing now. I read that if you pressed the button once then again holding it down you could shut the door, which id did. You could also open the door from the dash. If you shut the door manually you could hear the motor as the door shut tight.
This week the button on the dash stopped flashing and now does not open or shut the door, neither does the key fob open it anymore. When you shut the door manually the motor does not kick in. The door looks shut but when driving the interior lights are on and the warning beep is going off, also the door is showing as open on the display by the speedometer.
Any ideas please ???
