The passenger window goes up and down BUT you have to press the button repeatedly:
- If you press the button/switch it moves about 1cm and stops, so you have to press it about 50 times to get the window down or up. (This is the same when you press & release, or press & hold)
- Also, you have to press down to go up and up to go down.
- This is the same when you control it using the driver's side button/switch, so I'm guessing it's not the switches as both sides have the same outcome.
I've had the door cards off and there's nothing obvious to look at it. The buttons/switches & motor are functioning, but something along the line has gone awry. Regulator?
Anybody ever had something similar?
It's a 2001 T4 Caravelle Auto Variant
Surely if the Up goes down and the Down goes up then the relevant wires have got themselves reversed at some time.
Either on the push button or the motor.
I'd guess the error is at the motor as its doing the same from both driver and passenger side buttons.
If those wires are reversed then I guess its possible that other wiring has been relocated !! which may be causing your limited amount of powered window open or close.
