I have seen a pair of VW origional electric window motors. It is just the motors and the short bit of wire and connecter coming from it.
My question is what else do i need to make these work ? I do realise that i need to make up some kind of wiring loom and i will need set of switches to operate them. But is there anything else inside the door that i need ? Do the origional VW motors attach to the back of where the window winders are ?
Any help please.......
Regards Si
Pedal box guru
You will also need the correct mechanism to enable the motors to lift the windows.
The loom can be made without too much trouble. the switches don't need to be VW but do need to be 5 pin switches.
Hope that helps.
Cheers Trev.
