Help please. I have just got a new regulator for my electric window but it only has two wires coming from it. The old regulator had an oval connector with 6 wires. Would anybody know which two posts I should connect the two new wires to in order to make it work. I can hold the two new wires against the larger two wires on the old connector and the window goes up or down but need to fit them so the switch works.
179644
179645
179646
Special Rapporteur
What year van, and which side - driver or passenger?
As a generalisation, if the old part had 6 wires and the new part has two, then you have the wrong part!
Drivers side on a 1999 V reg.
If I hold the two wires to the two larger wires on the plug, the window will go up or down depending on which way round I hold them.
Special Rapporteur
You'll need to ask in the T4 section, but as said already, if the old part had 6 wires and the new part has two, then you probably have the wrong part...
