hi
all my little signal/air hoses are perished does anyone know the size so i can find some new coloured ones please
thanks in advance
cheers
Hi I am searching for this information too.
Anyone know the answer? They are the black ones that are above the engine? they look like a few mm diameter.
Matt
http://cgi.ebay.co.uk/3mm-ID-Silico...CarParts_SM&hash=item27b8cecf4e#ht_1393wt_905
here ya go 3mm silicon vacuum pipe.without sounding off,it took me less time to find this using the search facility:*,than to type the response?
theres sooooo much info on this site,thats been covered before,im not sure of the larger size vac pipe,guess at 5mm?
ps.youve reminded me to do mine A::D
thanks for taking all that time to only answer half a question
maybe if you had used the search you would of found both sizes lol
i started this post after using the search thread, did not found what i was after, i needed a quick answer so i thought i would start a thread. i am sure its not a crime
anyway i just when to a motor factor and took a bit of hose with me, job done,
as i just matched it up in the shop i still to this day do not know the size lol
pinch of salt etc etc
