I have a 2.5 TDi ACV 102 Caravelle, My glow plug light started flashing a couple of months ago, put VAGCOM on and it shows me that the "engine coolant temp. sensor" is open or short (can't remember the fault code). Decided it is time to change the darn thing, problem is there are two sensors, one in front at the bottom and another one close to the water expansion tank. Does anybody knows which one to replace?
Will other VW coolant sensors work? I think it is only the temperature range that differs?
My oil light has also started flashing the last week or so, did the bonnet switch thing, but problem is still there. Anybody changed the sensor, is it a pain?
Thanks in advance!!!! *<
> hohoho
