A friend of mine GAVST4, Has just called me,
He changed from 4th to 3rd gear earlier, and large clunk sound from up front, now engine jumping backs and forwards, and vibrating heavily through the cab, Any idea on location of them on a 96 1.9td??
Thanks guys
One either side of engine and big un from bottom of engine backwards...this is the one prone to playing up..If i can remember you jack up the engine to just catch the wieght and gently twist this mount to check wear in rubbers...its a dealer only part as well:eek:
The part is called the pendulum mount .just changed one .About twenty quid from Brickwerks .video of the quite easy job on you tube .
Supplementary to above .Dont jack up the engine too hard or you will not be able to lever the engine forward to get the bush end of the mount in and out
