what is peoples understanding re-engine numbers. If a engine has had the number removed is that illegal? also heard that some recon engines have the numbers removed...is this true?:*
thanks
zoe
the only way i see it is if its been removed then the seller is probebly covering something up. if you put the engine in your van then get stopped at the road side by the rozzers doing one of there check type things then you will need to have a good reason why you have a engine with the number removed.
