My T4 2.4D AAB van got some serious overheating in a steep hill, the engine shut off and black smoke showed up from the exhaust and steam from the cooling system.
After it cooled down and I filled it up with water it runs normal again, but it is heating faster than normal.
The problems I found so far is the radiator fan control module had died, and the fans did not run. Connected the fan with fused jumpercable direct to the battery, but the temperature is still incresing to fast, and the air from the heater is too hot. Then I found the electric water pump did not run, but it is not broken. Hooked it to the battery as well with a fuse.. Toke a test run, now, the temperature is better, but rise a little too fast I think. Where is the sensor that controll the water pump located? Is it the one in the water hoze from the engine next to the glow plugs?
I hope this fix my problem. The temperature gauge inside my van has always showed the normal temp.
