Hi. I am having some issues starting the van. It's a 2005 1.9 PD 104 T28. It has got progressively worse at cold starting to the point where now it won't start it all. VAGCOM says error 16706 G28 and engine speed sensor no signal. It was originally implausible. I basically just wanted to unplug it at the harness end and check that the wires that end look ok. I have no idea where to locate it. It may well need to be replaced or could be just a harness issue that requires a better earth having read up. Can you assist me on locating the plug into the harness please? Thanks.
