Just a quick question
Does anyone know if you can take down AND remove the engine undertray without jacking the van up?
Ive done it loads of time when jacked up but havent got my trolley jack so I was wondering if theres enough room to be able to get it out from under while grounded?
Cant be bothered to go out in cold, wind and rain to remove all bolts just too find I cant drag it out lol
Cheers again
If it's not lowered, then yes (mine does - admittedly with the original early front bumper, which doesn't drop down very far at the front). You have to wiggle the back a bit to get it out of the slots, but it's certainly possible.
Somebody stop me!
can you get to what you need to by just lowering it down on the rubbers?? IMHO those metal hooks on the rear are a PITA and i cut them off with a grinder, it makes removing and fitting it on the ground far easier T:T:
Well i may have a water leak so ideally i need too get it off so i can put some cardboard on ground to see if its leaking.
I wanted to take the belly pan off without jacking it up too check.
always done mine on ramps ,easy,n safer than a jack.i cant remove mine flat on the floor:(
It's always worth getting a few blocks of 3" x 9" timber somewhere between 18" and 2' long, to drive the van up onto, so that you can raise the van just enough for jobs like this or to squeeze under safely.
On my lowered van with side steps, this was enough to get under mine and fit my heater more comfortably.
great idea T:
