1 - 13 of 13 Posts
hi all just wondering wether anyone can help vw t5 was running fine but all of a sudden it started making a rattling nose then stalled now it wont even turn over just makes a click once :* ive checked the oil and water etc and all is fine the van is an 05 plate with 44000 miles full vw service history so hope its nothing major cheers :confused:
Doesnt sound good:eek: Had a car do that once and it was the shell bearings:confused: Hopefuly yours is simple,fingers crossed:ILU:
Sounds like it might have seized up, best thing to do is get a socket on bottom pulley and see if you can turn it over by hand with the aid of a ratchet if not it doesnt sound good I'm afraid, same thing happened to a Mini that I was doing with a lad we fitted a 2.0 16v engine to it and he had given it a good run and as he turned to go into his Drive it just stopped and that turned out to be a spun bearing on the crank
Meithered to death
There is no bottom pulley on the 2.5 T5 engine.
Should have posted which engine you have to make it easier for folk to help you
1 - 13 of 13 Posts
