I'm constantly getting the error below (P0101). I've replaced the MAF, the connector and wiring seem to be okay. Not sure where it goes to once it enters the trunking.
I asked my garage to take a look while it was in for a service and they said they couldn't find anything wrong with the wiring but then said they ran out of time and to book it in again. So not actually sure what they checked.
I've read that the MAP sensor could cause problems with the MAF? I've had a look and again, the connector and wiring that I can see look fine too.
Is there anything else to check or any tests I can do with VCDS to diagnose or narrow it down? or failing that can anyone recommend where/who to take it to in the East Midlands area?
Cheers,
Charley
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 17
Reset counter: 255
Mileage: 277281 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 2268 /min
Speed: 94.0 km/h
Temperature: 26.1°C
Absolute Pres.: 1050.6 mbar
Mass Flow: 27.02 g/s
(no units): 1.24
Temperature: 87.3°C
