1 - 10 of 10 Posts
Hi hoping for some help with my EPS fault, the light came on two weeks ago I took the van to the dealers for a service they had a look at the fault code and said it was a brake pressure sensor fault and wont reset? they then said they need to hook it up to the diagnostics rig for 2 hours @ £75/hour to find out exactly what was causing the fault. After reading the forums here I downloaded VCDS-lite and purchased a lead from ebay, I ran the scan on the ABS tab and heres what it said.
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Any ideas where to start?
Thanks for the info/link it sounds like the sensor in the abs module.... expesive! going to take it to CPC auto electrics in Telford to see what they think £30+vat to do a scan.
Thanks for the suggestion Sweety but just got back from CPC and they recon it's a faulty brake pressure sensor located under the master cylinder. £70+vat for the part total including diagnostics and fitting will be £140+vat. I'll take it back tomorrow for fitting. I’ll let you know if it fixes the fault
Well CPC were spot on with there snap-on diadnostics, it was the master cylinder brake pressure sensor. Thank god it wasn't the ABS unit. Thanks all for your help
hello guys I need help
I have vw t5 caravella
2003 2.5 tdi 174 bhp
light come esp on dash
and I can pass mot
also i use ross tech to scane
come fault
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP-F.lbl
Part No: 7H0 907 379 L
Component: ESP FRONT MK25 0203
Coding: 0006187
Shop #: WSC 00485 210 91425
VCID: 3E7380396A8C3BEEA6F-5122
1 Fault Found:
00814 - Solenoid for Brake Pressure (N247)
i replace the solenoid on servo
and light still on
any one know what to do
Check the wiring to the part you changed.
The fault code is saying that there is an electrical fault in the circuit - this is not necessarily a fault in the solenoid itself.
Look up the circuit diagram, and check the circuit is good.
1 - 10 of 10 Posts
