A big hello, I'm new to the forum.
I have a 2.4d T4 that was overheating. Doing some googling I came to the conclusion that it was either the cooling system or a head gasket / cylinder head problem. To diagnose which I got myself a block check kit which uses a liquid to detect exhaust gasses in the coolant.
Using the kit the fluid turned from blue to green indicating a dodgy head gasket etc. I took the van to the garage explaining this and they were skeptical of head gasket problems so changed the radiator and did an engine flush. This cured the heating problem somewhat. The temperature gauge would sit in between half and three quarters.
I needed the cam belt replaced so as the exhaust gasses remained I got the head taken off and pressure tested etc at the same time and all was fine with the head other than the standard cracking between cylinders. I now have the van back and have just done another block check and the liquid still changes colour. I'm at a loss as to whether there was ever a problem or whether the issue still remains. I've tried the kit on my diesel car and the liquid doesn't change colour.
So I guess my questions are:
a. Are these kits full proof and hence I still have a problem
b. What's the standard running temperature for this van? The temp seems to always sit somewhere between a half and three quarters. I thought in the past it ran cooler but the dash had the dreaded dry solder joint so for a long old while I was driving the van without temperature and fuel gauges so can't remember exactly where the temp sat.
All help greatly appreciated.
Thanks,
Gav
(previously posted in general technical in error)
Thanks,
Gav
