Sounds like the is a bit of a leak near the manifold, as there is a puffing sound once the engine has warmed up. I am also in the process of replacing all the exhuast rubbers, but the clanging I am trying to stop has reduced but not stop. Any ideas with either of these?
Scott
there are reflective heat shield attached to underside of van, these prevent exhaust heat damaging underside, has one of these dislodged? their only thin metal/tin in appearance and do cause a noise if looseT:
You still running with a cat, or de-catted?
If ur clanging the 'brick' in the cat may have come lose?
