Removed my mud flaps off my old T5 140 to fit on new kombi and remembered when you buy the mud flaps they come with a small black rubber expansion nut with brass threaded insert that you pop into a small hole to screw into.
So off I go to where the van is and try and remove them but with not much luck as they obviously expand and have to wreck em to get out. So I think they are an M5 thread and the black rubber body is about 12/15 long by 6/8 mm diameter with a flange on the end to butt up to the wheel arch. Does anyone know if these are available from parts or any other options? They are like a rubber riv nut I suppose . Cheers smiffy
Discussion Starter #2
Sorry these were on the on the front .
