My camper has an ACV lump and I want to renew the injectors as it's done 140+k miles and I've got hold of some brand new VW ones with larger nozzles (.203s) so I can get a bit more power and mpg with another tweak to the map (Martin at Pendle did a nice job soon after I got it 18 months ago).
So I try changing the injectors and find they are well and truly stuck in the head. The high pressure fuel lines are well rusty but I managed to get all the union nuts cracked off without breaking any, but so far I have only managed to get one injector out. I got hold of a new connector nut from my friendly local diesel specialist so I could use that to twist the injector once I removed the fork-clamp. This worked with the one furthest left - I started with that cos it's got best access by partially dismounting the radiator. I've then tired the next and the next but they won't budge ( I soaked them all in penetrating fluid for hours beforehand). I've also tried a large slide hammer but can't get it quite in line so not as effective as it should be I suppose - still managed to shear off a bolt I used to link the union to the slide hammer, tho.
So what next?? Any ideas??
