I've just bought a 140bhp, 2-litre LWB campervan - '10' reg, 24,000 miles on the clock, beautiful in all respects - except one.
It has the manual 6-speed gearbox, and the gear ratios are very high. For instance, at 70mph in 6th, the van is turning over at just under 2000 revs. The problem is that, in all the gears, if you press the accelerator at under 2000 revs, there's a harsh vibration, until it reaches 2000 revs, then it smooths out. You can feel it through the seat, the steering wheel, the body of the van. It's just like you've chosen the wrong gear by mistake, and should be two gears lower.
I understand this engine should pull smoothly from around 1500 revs, with maximum torque in a band up to 2200 revs. So why is it vibrating? Is there a problem in the drivetrain somewhere? Oh yes, it's a 4-Motion, but surely this should make no difference?
As it stands, if I'm being law-abiding, I can't use sixth gear! Is its just there for autobahn driving, at 75mph plus? It seems daft to be driving along in 5th at 70mph - and will hardly be economical!
I'd love to hear from others with manual T5 facelift vans - is my experience unusual?
Brom
Brom
