They may have been machined out to fit another vehicle in the past, but if they are factory fit alloys as others have said they won't need spigot rings
Good to know. Maybe they are not genuine then or like you say have been adapted. When it stops peeing down I will take the back wheels off and measure and have a look to see if they look like they have been altered.
He isnt mate
If that was the case there wouldnt be plastic spigots on loads of after market rims ,
All the spigots do is centralize the wheel
The bolts mainly hold the weight and the friction between wheel and hub T:
Some manufacturers dont even have spiggots on some models of old , VW being one of them T:
Im not saying dont fit spigots as by centralizing the wheel they stop vibrations that can cause bolts to loosen etc but hold the weight of the vehicle no.
He isnt mate
This is what Ronal Wheels USA had to say about hub centricity...
"Hubcentric" is another term that is often not mentioned or is misunderstood. A hubcentric wheel is a wheel designed with a centerbore opening to match the exact diameter of the hub of a specific vehicle. The importance is that the weight bearing of the wheel, in reference to the vehicle, is accomplished by the hub and centerbore mating to an exact fit. The lug nuts/bolts' only purpose is to affix the wheel to the mounting surface, not to bear the weight of the vehicle. Often wheels that are not hubcentric create driveability problems--shimmy, vibration, and erratic tracking. Many quality manufacturers design their wheels to be versatile by providing hubcentric centering rings that snap into place inside the wheel, to make the wheel hubcentric. This is an important safety issue--hubcentricity is highly recommended.
Plastic or nylon is also incredibly strong, in compression.
The studs provide the clamping force, the friction reacts the loads. The hub is there for centreing only. It may react to some exceptional forces like a kerb hit but that would be exceptional and still very unlikely to move
If the spigot worked with normal loads then you would see fretting, since it is a clearance fit and not an interference fit ,
if it was an interference fit that might be a different matter or even a tapered hub centre but there not .
To quote a piece from your ronal USA piece " A hubcentric wheel is a wheel designed with a centerbore opening to match the exact diameter of the hub of a specific vehicle." its not its a clearance fit so not an exact match .
Bit of tech for you ,
Did you know an average wheel bolt at 14mm thread bolt done upto 122nm will produce a clamp pressure of around 4100kg on average
thats 1 bolt put 5 on a wheel and you can see the hub face to wheel face interference friction is pretty damn high and more than enough to support a vehicle and its forces
We are not going to agree on this and im not willing to fall out over it T:
we both believe what we believe in
chow for now
chow for now
no intention of arguing with you and I know you have a greater expertise on vehicles than I have, it's just that I had a wheel come off at 70mph that had been torqued correctly, but didn't have spigot rings. I have tried to research as much as possible for the reasons.
I now check the torque on my wheels weekly and my torque wrench is always in my van, so for me regardless of whether spigot rings are required or not, I will always use them and recommend for everyone else to use them.T:
Hi
I totally agree as i said in earlier posts there no way if the vehicle was designed to have spiggots you should run without them purely as theres no way you can centre the wheel accurate enough on the hubs without having some sort of throw in the wheel
Being uncentralised is probably what caused the bolts to come adrift with you .
Hi all my caravelle standard tyre should be 205/65/15 with load rating of 100
Does the same apply for winter/ snow tyres, we are off to the Alps next month I want not only the best snow tyres for the job but also the correct load rating and size.
Do vw recommend a different width for snow...
I have a T4 Caravelle X plate Yr 2000 and am having problems with wheels. I was on holiday a couple of months ago and hit a pot hole that damaged my alloy wheel beyond repair and have been looking at ebay every couple of days to match up without any luck. The alloy wheels I currently have are 18...
Does anyone have a set of banded steel wheels for a t4
I have either a set of Calibre 18 inch alloys in Black (two of the tyres are new)
a set of winter wheels 17" with new tyres
or a set of ATS Deepdish Rims 4x100 (For a mk1 golf etc) if anyone is interested, will upload pics later.
Ideally...
My friends I have a problem. I will show You my Multivan, it is lowered -40mm, and I want to change rims in it. I have bought DOTZ LAS VEGAS as on pictures 18x8H2, and now I am considering what tyres will fit. I must say I would like to have as much tyre profile as possible, and I know, I should...
