hi guys.
Firstly does anyone know where i can get a genuine factory second hand reverse sensor loom from?
Secondly - i have a sensor thats not working. i've checked the actual sensor itself by swapping it around into the other femal connectors and it's working fine. Therefore the problem is either the female connector, or a wire running back to the connection inside the van. If anyone knows whether each sensor has an individual wire running back inside the van, or they all just joing a main line that would help me eliminate one or the other and possible help me fix my current set-up.
Getting bloody annoyed with the beep every time i select reverse and need to get this sorted!
