After the help I received last time here thought would put another issue on here... done a forum search but can't find exactly the same issue...
Basically my dashboard heater blower switch will work fine on 3 out of 4 positions (air blower and AC) but not in the 'three o'clock' position which blows the air back into the cab.
It refuses to stick in position and if I try and force it into the correct three o clock position it will either pop back above or below and therefore not dispense air out of the blowers.
Also - this switch will keep rotating round 360 degrees on my T5 - is this normal?
Any past experience or fix ideas gratefully received, not had my T5 long so still learning...
Simon
