My van has the wax stat which opens and closes shutters on the back of the cooling fans.
The stat is seized so the shutters remain closed. The stat is on back order so the garage has disconnected one side and jammed the vents open on the passenger side fan.
So, should I get both fans jammed open, should I change the back of the fans for the later model which apparently don't have vents or should I get the garage to order a new stat and hope the rest of the mechanism is OK. Don't know when this part will be available.
This is part of the over engineering of T4s. (They made them well in those days which is why they last so long) Do these vents being open or closed bring any advantage, presumably there for a fast warm up of the engine and then should be open.
Advice please. Thanks
