1 - 12 of 12 Posts
jabby fingered, worn nubbed, ginger ninja
Drop it off a cliff, it'll reach 125 mph
Momentarily:D
Failing that, search for 1.9 project power and it'll give you all the info you need.
It's basically, remove egr, stainless exhaust , intercooler , boost gauge and wind up the fuelling and boostT:
Its a VAN .....!! Yes , you can , but how much are you prepared to spend ..?? Little money , BIG headaches ..!! Depends on what you want ... and how deep your wallet is ..!! 2k might get you some power , but then you have the rest of the van to make it look like its got it..!! If youre looking for an ego trip , dont expect to spend less than £5 k . ( respray . alloys , etc . etc . ..... I just enloy mine for what it is ..!!
07415125940
2k is a heck of an exaggeration mr grumpy.
Project power only costs 600 tops with remap for example.
It's when you go over the 170 bhp mark that things get expensive.
Pp3 should be cheaper as the adjustments are manual and no remap required.
Just posting to keep things In Perspective.
Ron
Thank you , Mr . Rake ...At least the OP has a figure to start with ..!! Trouble is , the blue mist has a tendency to kick in , once folk start ..!! First thing to evaluate is whether the motor is in good enough order to make it viable ..!! And if there are issues , to resolve them first ...
5k is a good number. Bearing in mind the van is as aerodynamic as a brick, buy an old imprezza for 2 k. Spend three on making it comfortable and pimp. Youll get their....in a pimptastic comfort wagon.
1 - 12 of 12 Posts
