hi guys. I have just replaced the exhaust manifold gasket as it was blowing badly. Now after reassembling everything I'm getting the following fault codes and the van is in limp mode. Am i right in thinking this points to a faulty dpf or do you think the sensors have been damaged during removal of the dpf? Although I was very careful?
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 RT HW: 03G 906 021 AB
Component: R4 2,0L EDC 000SG 2120
Revision: --H11--- Serial number: VWX7Z0J03NS15U
Coding: 0000032
Shop #: WSC 35110 377 00176
VCID: 020BEB235D422C5431-8056
8 Faults Found:
008214 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 - 000 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 100.2 %
Lambda: -0.6 %
Lambda: -2.3 %
(no units): 2.0
001031 - EGR Sensor 2
P0407 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -10.4 %
Mass Air / Rev.: 640.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000000
006488 - Exhaust Gas Temp Sensor 2 Bank 1 (G448)
P1958 - 000 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Mileage: 80 km
Temperature: 924.0°C
Absolute Pres.: 1611.6 mbar
005213 - Exhaust Gas Temperature Sensor 3
P145D - 000 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.16 V
Temperature: 24.3°C
Temperature: 288.0°C
Temperature: 324.0°C
001350 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0546 - 000 - Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Temperature: 24.3°C
005269 - Switch-Over Valve for EGR Cooler (N345)
P1495 - 000 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000100
001139 - Exhaust Pressure Sensor 1 (G450)
P0473 - 000 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 232579 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:28
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Mileage: 80 km
Absolute Pres.: 1764.6 mbar
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 232579 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:34
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.00
(no units): 0.0
Bin. Bits: 11001001
Readiness: 0 0 0 0 0
