Hi, just found out my heated mirrors switch on every time the van is started, & they stay on until engine is switched off. I assume that you can normally switch them on/off via the door switch by moving it up/down, but this doesn't seem to work. Any ideas for a possible solution greatly appreciated before I contact an auto electrician. Thanks. :*
To turn them off just turn the switch to left or right mirror position, only heats when its pointing straight down to the heating symbol.
