I'll be fitting a reconditioned engine after the existing one failed, is there anything else I should get done at the same time whilst the engine is out from a long term maintenance and/or improvemwnt pioint of view?
One thing I was going to get done was an EGR blank, anything else?
Well as long as you don't have weak little legs, swop out that DMF clutch and replace it with a solid one. I changed mine when it went and I've never had a problem with it.
Check...
oil cooler...core plugs...crankshaft pulley vibration damper....inlet manifold for cracks..... driveshaft gubbins
You can tell that these are some of the things I wish I had checked !
