would i need special bolts for fitting a rock n roll bed to my t4?do i need more than just a nut and bolt?thanks,Adrian
You will really need spreader plates as well. 2mm thick about 100 mm square with 10mm hole through the middle. Use M10 bolts about 75-80 mm should do and lock nuts. T:
If your rock n roll bed doesnt have any seat belts attached to it, then a couple of bolts will be good enough to hold down the frame. If its built to take the pull of a seat belt, then at least half a dozen 10mm bolts through spreader plates and chassis rails would be a good idea.
To give you an idea, this is how we tend to fit ours:
This particular photo is a T5, but you can see the brackets.
