Hi All,
Finally took the plunge after must reading posts on here and decided to go for the Eibach 45mm springs to try and get some drop on my van without imparing the ride quality.
I've head the technical article on how to fit these and managed to do the offside this afternoon relatively easily!T:
However, on the nearside, when I turn the 16mm bolt on the bottom of the strut, the strut turns with it and is not loosening just spinning. I have soaked it in Plusgas and tried turning both ways to see if I can loosen all to no avail. I even got the blowtorch on the nut to see it heating it up a bit would work but no good and couldn't heat it too hot because of fear of torching the rubber bush directly behind it.
I even tried holding the strut a best as I could with some water pump pliers and the tried to turn the nut (although I needed another pair of hands realy) but still no good.:*
I'm sure I am making a schoolboy error here but seem to be living up to my username!!I:I:I:
Could someone be kind enough to teach me the error of my ways please? I need van for work Monday and don't want to be driving it with different springs on!
Also, on the side I changed, I measured from centre of wheel nut to bottom of wheel arch before and after and reckon this has gone from 450mm to 440mm so only 10mm drop! I thought these were supposed to give 45mm drop and as I have the slimline mounting plates from T4srus was expecting more like 50mm.
I appreciate my van is very light (no interior not even ply at the mo and spare wheel removed to reduce weight/ fuel some weeks ago) but was hoping for bigger drop than this! Anyone else done this and seen bigger drop - if so what am I doing wrong?
Cheers,
Chris
Cheers,
Chris
