Hi all,
I am a newbie van owner and I've not posted anything on here worthy yet so I apologise if this is the wrong place to put this but I thought that I should share my very slow van story with you in case it can help anyone else.
The van was slow up hills and seemed to lack in power but started first time everytime.
I changed all the vacuum hoses, blanked the EGR, replaced the intake manifold and its o ring and carried out the cage mod. Still it was slow. I unplugged the MAF sensorand the van ran better so figured that must be the culprit.
Final try before shelling out on a new MAF I discovered that on top of the fuse box above the relays there should be 2 blue 15 amp fuses on their sides. My '02 Caravelle only had 1 in and the other space was empty. I put one in to see if anything changed and woosh! Full speed ahead! Its like a different van A:
Does anyone know what they are for?
However, now the van struggles to start first time. It takes 3 or 4 tries and makes a terrible gear crunching starter motor sound and then it sounds like somethings come off!
When it does start its great!!
Does anyone have any suggestions?
