Hi all,
I've just had a slightly worrying experience in my T4 2.4D
I hadn't driven it in about 2 months because of lockdown and just went to give it a spin. Engine started fine but could hear a flapping noise from the engine and had very little power. It moved but I couldn't get it up the ramp from the car park. I went to inspect the engine and the noise stopped after a minute or so. Everything seemed fine after that and drove more smoothly than I remembered it did before.
I thought it could be a timing belt issue but I had that changed just over a year ago! Maybe fan belt but that wouldn't explain the loss of power.
If anyone has any ideas, please help me!
Full of Cr*p....
Pigeon stuck in the air intake!
Sorry, don't know the engine so nothing sensible....but hope you got a smile..... :)
EDIT: OH....sensible(ish) answer:
Alternators have been known to seize if unused....would put a vast strain on the engine, and possibly make the belt flap?
Full of Cr*p....
Try taking the belt off?
I "thought" the big units on T4s would be OK, but on my Smart forum, read about people fitting new, driving 3 months, parking up over winter, and engine won't turn over at all! (700cc engine...LOL)
Squirt of lubricating oil (NOT WD40!!!) into it, cures it 90% of the time.
Also, do you have P/S.....maybe that pump is causing drag?
Aircon pump (though doubt you have it).
What do you mean by big units?
It could be power steering, was gonna be a job to look into that this weekend as there's been a bit of a squeal when turning. Probs just low liquid though
No way do I have aircon haha
Full of Cr*p....
Well, by "big units" I meant a Smart alternator will just about cover the palm of one hand....the T4 on needs 2 hands (and as the old joke said, I still piddled on 3 of my fingers!).
The clearances in the T4 90-120-150 alternators are much greater than the tiny one I was talking about.
BUT...IF you have salt on your roads (LOL...your "flag" is for "gawd knows where"..certainty not Peterborough), but yeah...you have SALT on your roads.
I'm lucky where I live..they don't use it...just plough the roads and leave 2" of snow for grip (studded winter tyres :D )
Salt gets into the rotor.....rust froms between rotor and stator, and takes a LOT off effort to 1st free it.
Once rotating....it should be OK...until next time!
I'd say....1st test, remove the alternator/PS belt.
You can drive a fair distance without (depending upon arm muscles), and see if that cures it.
Then you have narrowed it down to 2 problems.
Leave 2" of snow? We can't drive over here even when the roads are clear but the pavements have a "wet look" to them. :ROFLMAO:
