Looking for some advise where to start.....
The timing belt broke a few weeks back and i got the engine rebuilt. The pump timing was reset correctly, and no codes came up on the code reader. There is a nice bottom end power up to 2k then nothing much after (struggles to get to 70mph). Its a 88HP AJT....
I thought ask here (the experts) before sending it back to the garage and have them spend hours trying to source the problem! I:
Check your Boost control valve (N75) is piped correctly as this will put you into a 'limp home' mode if it's wrong. It's located by your rad exp tank
Look HERE
